12ValveHyundai
Hello, did you find a solution to this problem? I am having identical issues with a old Hitachi. Did it end up being the overload relief valves on your machine?
I took apart my drive motor and everything seems to be fine but my shaft seal keeps blowing in towards the reduction gear motor. Case drain line appears to be clear to tank. Any help would be appreciated. Thanks.
Have you checked the relief pressures at the pumps? It's usually pretty easy. If you don't have gauges you can pick up a cheap set on amazon for $100, they're well worth it. If your case drain is fine (confirm this, it is the usual cause of this problem) and the pumps are relieving at the correct pressures then my bet in both cases would the swivel joint (turning joint, rotary manifold, or whatever else your manual calls it). The teflon seals inside it need to be replaced periodically. In extreme cases grooves can be worn into the cylinder and then the whole thing needs to be replaced. I can't really explain why it does this, but it seems that pressure ending up where it's not supposed to be when it's not supposed to be there can blow those seals. I had the same problem. The swivel joint was easy to rebuild, seals were $200 and I resealed it in an hour on the tailgate of my pickup.
