Hi Mr. Kobelco,
What you write is all true but is not the main problem. When I disconect the el .wire to Pf solenoid, all problems are still there and also engine stalls when you push pump to hard. If I tried realy hard to lift lift ful bucket of rocks I coukd lift it litle more quicker than whith computer help.
What I found up:
1.) when prop valve disconected pf=0
2.) I tried to close bucket ( to fill it with 1-3 inch rocks) but bucket did not want to close and the pressure riest in moment to 290 bars ( I monitor only P1) and pump regulatet to 0 I think and engine did not felt enythink.
Than I pull right travel comand when all machine was blocked with bucket in rocks and I saw that travel relief is set to 350 bars. After that I pull travel comand to cca. 300 bar and also engage bucket for diging. Than sudenly bucket started to move ( close and loading the rocks) at pressure of cca. 200-250 bar. After that bucket and boom worked almost good ( but cca. 1/3 to slow) and arm still did not have power to tow complet machine when closing.
When bucked now was closing under heavy load I could here whiseling from valve I think.
I also notice that full loaded bucket is lifting with boom at 150 bar and real slow.
So I think that travel limiter could be cought somwere in the middle and throttle main flow. So could that be the couse? Could pilot pressure which suppose to lift the travel priority spool againstthe springs when engaging both travel and attachment leaks to that spool wheen it should not?
I attached the picture from which I think that is seen that this spool is forced in upper position ( from brown color which sould be oposide with bright part).
I will try to attach the immage here.
Regards,
Gregor
