Connstellation
Hello, I've got a few topics, 2 machines that are fighting me.
I have a kobelco 160-vi [according to cab decals, but I can't find a serial plate to confirm]. I thought it was a dash 4 but Roman numerals are hard for some reason.
I've got variable slow machine function, sometimes semi quick, usually slow. Also an arm cylinder that will boom out on its occasionally at various speeds/ positions. Im suspecting the two are at least half related because the rod seal is leaking fluid and sucking air.
Unfortunately this machine was abused, neglected, with hack and slash fixes. I have codes for battery relay [it was bypassed], engine speed sensor, mechatro control failure [I can't be sure, but i think since the battery relay], h-4 offset [?] and p1 bypass propo, which from what I understand is the latest and most related code.
Things I've done/ am doing:
Since I'm not sure on my serial number i can't order a seal kit yet for the arm cylinder. Im not sure if it's a 125 or a 130mm bore until i can take it apart.
I've spliced the engine speed sensor [wiring was corroded/ split]. The sensor ohmed within spec, but voltage was 3.5vac. The manual wants at least 4. Im assuming I can adjust sensors depth to get it within spec. I can't however, get to the sensors menu page to see its readout for some reason?
I've spliced the governor's wiring.
I've replaced a1 [operation lever lock] and a2 [power boost] solenoids as one shorted and the other had deteriorated insulation causing it to have half the resistance making it excessively hot.
I've been through almost every spool/relief, but plan to recheck [in case I've missed something] the arm functions, conflux, recirculation, and travel straight after I reseal arm cylinder.
Replaced p1 pressure sensor.
Checked/ ohmed wiring to solenoids [controller to solenoid plug]
Completely rebuilt pump probably 700 hours ago because other had grenaded. [I didn't have any debris when I cleaned most of valve body but possible I missed something as I did this months ago]
Here's my diagnostic information at idle:
Ym22e0008f1 ver 3.99
@80% run
So i don't know when these sensor readings wacked out. Im assuming some are new and some are old. Anyone have any ideas on what my next item to attack should be besides the cylinder rebuild? Why is my d-1 not giving feedback and why do I report pressure on p1 with machine off or idle? It looks like all arm related cylinders are wonky and im not sure if it's because a1 lever lock went bad and heated the fluid hotter than usual, air, wiring I'm somehow missing, or all of the above.
Ps I forget what the actual number is, but both pumps are capable of outputting 3xxx or 4xxxpsi.
I really appreciate any input.
- Eg set 1050. meas 907
- Accell volt 3.5. Pos 83%. Step 280. Pos 8%
- Step coil a 1.5a. Coil b 1.5a
- F-2 swing brake comp on. Meas on. Release off.
- F-3 1/2 travel comp off. Meas off. Switch off.
- I-2 bat relay comp on. Meas off. Key on.
- Boom raise 0.4v 0p. boom lower 0.4v 0p.
- Arm out 0.4v 0p. Arm in 0.4v 0p.
- Bucket dig 0.4v 0p. Bucket dump 0.4v 0p.
- Swing right 0.4v 0p. Swing left 0.0v 0p [????]
- Travel right 0.4v 0p. Travel left 0.4v 0p.
- Pump p1 0.5v 87p [this fluctuates, with machine off its 57ish always] pump p2 0.5v 14p.
- Propo d-1 p1 bypass comp 200ma 0p meas 13ma 0p [?????].
- Propo d2 p2 bypass comp 200ma 0p meas 205ma 0p.
- D-3 s travel comp 350ma 100p meas 346ma 96p
- D-6 arm recirc comp 706ma 413p meas 482ma 225p
- P1 pump 433ma 164p meas 423ma 155p p shift 0
- P2 pump 433ma 164p meas 426ma 157p p shift 0
- Mechatro sw run, vol 50%, prog sw off
@80% run
- Eg set 2215 meas 1974
- Accell 3.5v, pos 88%, motor step 431, pos 80%
- Arm out 0.6v 14p [manual states 0.4v to 0.5v, .6 volts is out of spec, it over volts when arm cylinder acts up more or vide versa]
- Arm in 0.4v 0p.
- D1 p1 bypass comp 453ma 190p meas 18 ma 0p [????]
- D2p2 bypass comp 453ma 190p. Meas 448ma 1849
- D-6 a recirc comp 706ma 413p meas 488ma 220p [???]
- P1 pump comp 350ma 81p meas 341ma 83p. Power shift 120ma.
- P2 pump comp 350ma 81p meas 340ma 83p. Powershift 120ma
