funkinalive
Hi everybody, i have a CLAAS ARES 557 tractor with 1460hrs. I know most of you are not familiar with this machine but it has a JD motor and an MF transmission (24 speed Hexashift). the problem i am having is that the tractor operates with absolutely no issues, but lately i have noticed a nast knock when the motor is shut down (definately not like this before). specifically as you turn off the motor it winds down and right as its about to stop there are two to three loud knocks which i believe is coming from between the engine and transmission. i have no idea what this could be, i checked the tensioner and engine mounts, and they seem fine, its dificult to localize the noise but i think its coming from the bellhousing between the transmission and motor. loose flywheel maybe? broken clutch plate or disc? Im wondering if anybody has encountered such a problem before? thanks for any input
Sincerely
Mike
Sincerely
Mike
