Just some work pics
crane operator
sw missouri
They say the tadano's are a really nice machine. I'm sure I'm not their buyer, but its nice to look at new iron.
On the old iron front.... '98 Western Star that I pull my lowboy with is putting antifreeze in the pan. (60 series detroit 12.7) Liner, head, water pump, or air compressor. My regular detroit man is three weeks out. He recommended someone else, and did mention that its likely the head cracked in his experience. I haven't even pulled the pan to see where its coming from.
One of the guys went to start it the other day, oil was just on high part of the line, but water was low. Added antifreeze and started up truck, by the time it built up air and he had the snow shoveled off, the low water light was on. He then pulled the dipstick again, and it was all milky on the oil. Pulled the pete under the trailer and got the crane delivered, but I'm going to have to do something. If I pull the head, I wonder if its worth it to just inframe while I'm there.
Unless its just the water pump, which would be great, as long as it didn't damage a bearing.
petepilot
central shenandoah valley va,
Unless its just the water pump, which would begreat, as long as it didn't damage a bearing.
my first move would be pull the pan fill the rad. pressurize it and then with a good drop light go under check both inside and out of all liners for drips
f311fr1
Middle TN
How much longer do you want run the WS? If the rest of the truck is in good shape and there are a lot of miles on the engine I would probably do the in frame.
crane operator
sw missouri
Replacing some steel on the back side of a pool building. Its a two story wood/ window wall.
The water ate up some of the wood inside, and they are replacing with steel, but I think the chlorine is going to eat the steel faster than it did the wood.
20210203_111519.jpg 20210203_111333.jpg 20210203_111351.jpg 20210203_095609.jpg
crane operator
sw missouri
Steel frame building. This guy had some bar joists they saved out of a building. He's a welder that does a lot of fab, and is making a bigger fab shop. He does good work and has been really growing.
1/2 the building for powder coat, other half for fab. Can't get decent powdercoating done, so he's going to do his own.
crane operator
sw missouri
That's got to be a 500-700 ton hydro. Most of the time when they are fighting them up a mountain, its for wind farm work.
Looks like its either a 700 or 1200 ton by axle count.
Natman
ID
That was impressive!
I just set the 4,000 pound cab back on some AWD ex military rig (I think it was used for tank recovery, 6 axles, tires 6' tall ) after some engine work, that is currently being used for towing some big cranes the last couple miles to a wind farm site, or so I was told.
mitch504
Andrews SC
A HEMTT?
Or something bigger?
would have liked to have seen the take off after stopping on that grade
I imagine the carrier is equipped with a powershift and a torque converter. It was probably quite unspectacular.
I WAS impressed with the manoeuvring around the hairpin bend though........ reminds me why I like ATs.
A 1200 according to the operator's web site. Apparently they are a specialist outfit dedicated to wind turbine assembly.
https://www.windhoist.co.uk/
