Been rainy and icy/ sleeting here the last couple days. Had a little shop time, so got the fenders painted up, deck is cleaned and primed.
Got the hard lines welded into the new / old hyd tank. I capped off the lines and did a little hydro test, no leaks. Three pipes on the drivers side, one on the passenger. I think I'm going to put little wedge braces on the pipes so they don't vibration crack.
I was going to put the old bolt on access cover in the center of the tank, but when I cut the top off, there are three baffles in the tank, so there's nothing you could really see by removing the lid. The intake filters on each side are behind the baffles, so I could mount the bolt on cap, but there's nothing to access under it. I think I'm just welding the top shut, that also eliminates a water intrusion place (the bolt on lid).
I don't know what the old tank came off of, but I know the Hyd pump it was feeding had to be junk, the tank was full of nasty gritty junk. Me and the mechanic have both been to the car wash, and its had 2 diesel baths. I think I have it clean enough to use now, but if they were running that stuff through their pump, it couldn't have been making much pressure anymore.
Tomorrow is supposed to be more rain, so I'm going to try to get the sight glass, filter base, and the top caps made and welded in. Fill pipe and breather mount in the top caps. Then I can mount the tank to the truck frame, and get the exhaust remounted. I think we're going to just straight pipe the exhaust, with the muffler its hard to get in the passenger door, it doesn't open very far because of the air cleaner. That mack isn't very loud.
