Will-Power
Any good Deere mechanics out there, I have a customer with a 6068 engine with the following codes and symptoms. Unit has lots of power and runs fine for 30 seconds when he begins working and loads it up it loses power dramatically and smokes a bit.
I am thinking he may be drawing air into the suction side of the fuel pump, he changed his fuel filters 100 hrs ago, I told him to do it again and check out his hose from the fuel tank to the first filter.
Any thoughts??
Spn 94 Fmi 17
Low pressure fuel signal slightly low
Spn 1347 Fmi 7
Suction control valve circuit mismatch
Spn 94 Fmi 3
Low pressure fuel signal out of range high.
Spn 971 Fmi 31
External derate switch condition exists.
Spn 1569 Fmi 31
Engine power derate condition exists.
Any thoughts??
Spn 94 Fmi 17
Spn 1347 Fmi 7
Spn 94 Fmi 3
Spn 971 Fmi 31
Spn 1569 Fmi 31
