porschetmc
Hi guys,
I have a 2010 JD 319d. It has been throwing codes 94.18 and 94.04 which are low fuel pressure codes. Once one of those codes come up it will start to derate the machine. If I pull of the sensor (by the fuel separator) the engine will not derate. I changed the inline filter and the water separator but has not fixed the problem. I also replaced the sensor. If you run it without the sensor on it will run fine until you are running at high rpms, then it slowly drop rpm until you let off the pedal for a bit.
Has anyone had this issue? Could there be a dirty screen in the tank?
Thanks for the help,
tim
tim
