Mark250
- Joined
- Aug 30, 2015
- Messages
- 1,243
- Location
- victoria,Australia
- Occupation
- heavy equipment technician
Hi guys, in need of some help with an 8430H please. this tractor is new to us and is towing an air seeder with a hydraulic driven fan.
The problem is that when you turn the machine the fan slows down and if you are not careful the seed tubes will block which is a pain in the a#se
i am assuming that the steering has priority over the rest of the hydraulic system and i have some questions
Can i get controlled flow to air seeder independent of steering?
Of the 3 outlets to seeder is there a specific port that we can use for the fan motor to stop the speed loss
Could this indicate a pump that is on its way out?
Any ideas or suggestions or help in this matter most appreciated
Mark
Mark
