john deere 650G LGP
Chesterfield X
Chesterfield va
New problem, I started the dozer up and once you lift the park brake lever it goes directly into reverse? No forward speeds at all? Strainer at pump is clean, all fluid and filter has been replaced. 5500 hrs on machine.
Chesterfield X
Chesterfield va
Yes, I did find the short rod that goes from the shifter linkage to the trans control valve shaft had come loose, I reattached that and now the left side track is like in neutral? This rod is held on with cotter pins , One had broken out. Is it possible that maybe when that short rod broke out it could have messed up a O-ring or something inside the trans control valve box that would cause fluid to flow in the wrong places ?
