Scott McFadden
I'm working on a John Deere 450C LC excavator and it loses hydraulic power and the engine bogs down to the point you can stall the engine while trying to operate the controls. When this occurs there is an engine light, but I don't know how to read codes through the screen on this machine. When the engine stalls it does not restart until you prime the fuel system. I drained some water out of the fuel/water separator primed the fuel system and the problem went away.
This problem has occurred a few times, intermittently over time. The fuel filters were previously replaced. Fluid levels look good. I'm guessing there is debris stuck in a fuel fitting somewhere. Any tips for the most common places to look? Thank you.
