Hi, first post time poster here. I apologize for long post, just trying to give you backstory, hopefully I can explain my issue well enough.I bought a 410D last fall with a rusty cab. Found a different cab, and took on a good winter project changing cab. I finished it mid january, and used it in the snow, and woods and for the most part worked pretty good. We have been having warm weather here lately, and I am using it to clean ditches, and fixing wet holes in fields. The problem I am having is when i use it for a while, and it starts to warm up it goes into a neutral like the parking brake switch is turned on. If you cycle the parking brake switch, it will move normally for a while, then it gets to the point where it disengages as soon as you cycle switch. I manually disengaged the parking brake as it will not release the parking brake when it is acting up. The cab is off a 410D with a newer serial number, but all the wiring, and switches are off my old cab. I think the only thing I changed was to put in a electric temperature gauge in place of the idiot light. The vin on my hoe is 786624, the cab vin is in the 800000, but do not know exactly as the place I got it from would not give me the donor machine vin. Thank you for any help I can get
