JL Sargent
Reminds me of the time I found the fuse holder itself to have failed due to corrosion.The best test for an old fuse is a new one.
where do i buy these?I doubt they are repairable. The nut on the top comes off and they should pull off the stem.
It might take some force if the dirt and rust has built up.
i had cleaned those wires, i was looking at that one first and I used some contact cleaner.Those clean red wires and yellow connector make me wonder if someone has rewired the solenoid and left the frayed wires loose. Does the nut magnetize when the solenoid is energized ? Might tell one something about its operation.
Slow down... Make sure you're not throwing parts at it.where do i buy these?
Yea, you can see the solenoid in the first picture too. That one wire was already disconnected and then i reached down to feel for the other and it came right off, like it was hanging on by 1 strand of copper.That solenoid in the second picture in post 24 does not appear to have any wires on it.
Is that correct?
I managed to get the top bolt off.
Does the top half come off? I'm a little confused.
It looks like there is another HEX area at the base to take the entire thing out. Do i do that or does the top half some how pop off?
If so, any suggestions on getting it off? Its in a really tight spot and getting the rest of it out is going to be an ordeal.
NUT, I mis-spoke, its just a nut.You removed the top bolt or nut?
