John Deere 410
Kgh65
Windsor locks ct 06096
Have a 1979 jd 410 and the minute we start it antifreeze bubbles out of the radiator .Leaning towards head gasket problems .Any other ideas
old-iron-habit
Moose Lake, MN
I would start there. A visual will tell if its a cracked head or possible block problem when you get it apart. Was it overheated lately?
Kgh65
Machine shop called today and said they found nothing wrong with the head . Any ideas on what to look for next .No oil in water or water in oil just pressure in cooling system
Willie B
Mount Tabor VT
Electrician
Cylinder sleeves can get a corrosion hole if anti freeze doesn't get changed often enough. On compression stroke you get pressure with minimum oil contamination.
Tinkerer
Does the machine shop specialize in checking heads for defects and damage ? In my area there are machine shops that do head work, but I would not trust them to do a proper inspection on a head that came off of a machine with gas bubbling in the radiator.
I see from reading your posts you have worked on different machines. Just curious if you operate a repair business.
Blake13
Granite Falls, WA
Any update on this? I realize this is an old thread, but I am going through the exact same thing with my '79 410. I haven't taken the head to a shop yet.
Thanks,
Blake
mg2361
Pennsylvania
Equipment Mechanic
Welcome to HEF Blake13;)! Should have started a new thread. Anyway, you could be looking at a head gasket, cracked head or holes in your cylinder liners. First thing I would do to give you a clue is drop the oil pan. Pressurize the cooling system and look up into the engine to see what cylinder the coolant is coming from. When you determine the cylinder move that piston to top dead center and see if the coolant is coming out of the liner (not a foolproof method as the liner could be cracked near the top). At least when you have to pull the head (and you will have to pull the head) you will know which cylinder to scrutinize.
