Herbert G VanScoyoc III
Pretty sure I've read every thread on this forum pertaining to the John Deere 410, chasing down hydraulic issues. Started with the obvious check the pick up screen, and change the filters no change loader still dead. PUlled the main pump rebuilt the destroking valve, new oring on the electric destroke solenoid, still nothing. Removed the electric destroke solenoid and installed the john deere plug eliminating the electric destroke solenoid out of the equation, still the same issue.
Broke down and bought some pressure gauges and adapters to do a pressure check found i had a 1000 psi standby pressure, and 0-25psi charge pressure 0 unless the engine was running wide open then i would get 25. Tested at the reverser test port got 150 psi.
Pulled the reverser control valve off disassembled it, cleaned it all out, all new gasket and springs, reinstalled adjust the shims to get the reverser pressure to 160, with new springs it now required 2 less shims currently has 4 installed. GO up to the mains pump pressures are still the same as before...
By now I'm getting rather frustrated and know far more about this hydraulic system than I ever wanted too. I find a thread that said to check the transmission filter bypass sure enough it was stuck still waiting for the new springs and poppet to arrive. Really hoping that was the issue.
If this was my issue I really hop it is and i go about setting my standby pressure to 2100-2200 psi while deadheading the main pump.
My current question is when i set the pressure control valve {steering priority valve} pressure, where to i attach my pressure gauge to get a reading will i remain connected at the pump output test port or somewhere else?
