John Deere 35d right spool valve
redrob
Kentucky
My 35D just started leaking fluid. Looks to be right propel valve. There's a hole in the side spraying fluid when right side tram lever is moved. Does not leak until I try to tram. Any ideas what is wrong?
mg2361
Pennsylvania
Equipment Mechanic
The travel plunger seals (items 5B and C) are leaking and probably filling the housing (item 8A) their in.
mg2361
Pennsylvania
Equipment Mechanic
Oh, the spool valve and not the pilot valve. I believe that was a steel ball pressed into a cross drilled passage. That would not be available. You would need to replace the spool section.
Monkeywithawrench
New Hampshire
MG.......could you tap a thread in the housing and thread in a plug?? Just curious.......don't know anything about JD and how its supposed to work. Or at a crude fix, weld the hole up?? Is the ball pressed in just to plug the cross drilled port?? Always trying to learn.
mg2361
Pennsylvania
Equipment Mechanic
I don't see why not. That is what I would try before replacing the section.
Yep. I am not 100% sure on that model but I know many cross drilled ports in our product line are plugged with little stainless steel balls.
