John deere 350D fuse layout and no start
GCC
Ontario, Canada
Excavation
Hey guys one of the operators got a machine stuck to the point then batterys were 12" blow water cat get power to cab unless back feeding power. Need a fuse diagram and curious if any one else has had a no power to cab issue already bypassed the disconnect
tool_king
new jersey
road mechanic owner
What is your email address ?I can email you the manual with the diagrams for the fuses.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
catalyst.. if yours is just blowing the fuse to the start solenoid on the inj. pump.. its normally the cold start sensor in the cooling system.. IF you have a Stanadyne inj. pump,
If you have 2 wires coming from under the inj. pump, follow them up to the connector & unplug it..
THEN replace the fuse..
It wont effect the running condition of your engine. its there to aid in COLD starting situations..
BUT if you want to replace the sensor.. just do a search.. the problem is common & the P# is readily found.
tool_king
new jersey
road mechanic owner
Catalyst
I emailed you a link for the proper manuals John Deere 350DLC operation,parts,service and support manuals .
