Have a crawler here that we removed the injection pump from and the timing mark on the pump wouldn't line up with the divit in the flywheel. I believe this is a rossa-master with the two umbrella seals on the shaft which stayed attached to the gear. This machine was running and filling the crankcase with fuel and would only run with return loosened. Would this machine run 180* out. Could the flywheel be mounted incorrectly? The pump is getting rebuilt and should have today. Any info would be very helpful. Thank You in advance
