John Deere 310g slow front buckett
Chris Brady
Oneida Tn
I have a 310g John Deere backhoe front bucket is very slow when operating and steering is hard to turn at idle looking for some help please
mg2361
Pennsylvania
Equipment Mechanic
Welcome to HEF Chris;)! Does the backhoe work normally or is it slow as well? Also need a serial number.
mg2361
Pennsylvania
Equipment Mechanic
Change your hydraulic filter. Then cut open your old one and see what's inside. Post results (and pictures if there is debris). Do you have service manuals? Are you comfortable with wrenching? The backhoe relief valve should be removed and inspected for debris in the end of it (make sure to relieve the hydraulic pressure before removal). If your loader valve has a relief (according to your serial number it does not, but look anyway) remove and inspect that as well.
