thank you for the reply. ser# xt0310sg897851 or it's TO310sg897851 the first number says it's a product identification number, where the next one is a number the dealer put on a ser# tag.
the transmission works fine in 1st forward and reverse with no slippage and has full power to work. when shifting 2nd-4th in either F/R it does nothing won't move or continue to move when shifting on the fly once i'm already moving. how ever weird as it seems, when i used the bucket to raise the front end and then tried 2nd in reverse, it would sometimes work and even in 3rd it would move without seeming to slip but this did not work if i tried going in forward except 1st gear. pick up the bucket while still in 2nd reverse it would move with out issue until you shift into neutral then it would not work again. i checked fluid thinking it might be low, but it was in normal range when the engine was running and warm. i did plug the brake wire back in and nothing changed and the brake has always worked fine.
just a side thought I just had, this issue just started while i was working the machine and i used the left side (i unlocked them to work separate for this move) brake pedal to steer and it seemed to start having the tranny issue shortly after. don't know if it's related or not but thought i would mention it. thanks again
