BackWest
Hi everyone, I'm new to the forum after recently purchasing a 2006 JD 210LE. I bought the machine back in August for misc. work around the house and keeping up on driveway grading. It's been running fine until a couple weeks ago when I started having trouble with the transmission disengaging while grading the driveway in 2nd gear. This is when I also noticed it wouldn't move if I shifted into 1st or 3rd gear (both forward or reverse after previously using 1st gear with no issues). However, I could get it to engage and drive in 2nd and 4th, but it would continue to disengage while driving acting like the transmission fluid was low. I checked the fluid level and confirmed it was low so I bought 5 gallons and finally had some time to mess with it this weekend. After adding a gallon or so of fluid and getting a good level on the dipstick, the machine hasn't been disengaging from 2nd gear while driving, but still no 1st or 3rd gear and it will randomly not engage in 2nd when throwing the lever from neutral to forward or reverse. I'm thinking it may be something electrical, but I'm by no means a mechanic so any advice on where to start would be much appreciated.
