od1
I have to post 3 times before I can start a new thread. I have a JLG40F manlift that has left me hanging to many times. That's not literial but actual. I want to rewire it but its been patched so many times that I'd feel safer if I had a wiring diagram. It has a few other problems as well.
1, it has to warm up for at least 20 minutes before the foward and reverse, the turit, large boom will run. The steering platform tilt and small boom will work right off the bat though.
2, The forward and revirce joystick positions are now the same. No matter which way I position the joystick it goes in reverse only. I switched joysticks and it's still the same.
3, The brakes do not hold. Are there pads? A friend of mine religns pads for skiders so all I need to know is how to remove the old pads (if there are pads that is)
Thanks to all for your time on this. You can reach me at od@intersat.cc
