want 2 get high
Hi all,
Another problem with the lift. Will start and run a very short time and die. I have checked the pulsing ground at the coils which it does have but when you first start to crank the engine the pulsing ground is not there for a short amount of time and then returns. Is this normal to have the delay of the pulsing ground? Is there a way to check the ignition trigger?
This is the 3 cylinder gas/lp model. When it is running and dies it is sudden which makes me think it is not fuel related.
Would an ignition module or ignition trigger fail this way? I will restart after a little and die all over again.
