I have a JGL 45HA. I capped the ports on the drive valve, and when operated one way, I can get it to the 3000 psi it should be. When I go the other way, it only gets to about 2400 psi. I swapped a valve cap end with a different function, and added shims to the spring, but no change.
The odd thing, is when I function another function, it will jump up to the 3000 psi, but not the drive function by itself.
I was curious if the dump valve could be causing this, but it seems like it is either open or closed. If it were leaking, it seems it would do it in both directions.
I ordered a seal kit for the valve, but was wondering if someone had some other insight. It seems it has to be internal to the valve.
