newly acquired 40ha, born 12-90 and lived it's life outside, std controls, LPG/gas, 2wd. Long story short I made an offer and the guy took it so I had to tell the wife " Honey it's cheaper than me falling off a ladder"
I'm having a few issues and the great JLG diagrams are not much help due to I can't see the damn things...
1. On LPG- Very cold shouldered, hard to start, but once running she does good
2. Gas-- manual pump and solenoid are bad so I used a boat tank and an elec low pressure pump to try the engine and it floods like a beast and runs terrible--Carb rebuild?? if so where in world would I get a kit?
3. upper lift cylinder leaks, the manual does cover this and I found parts, not bracing the beast to pull the cylinder.
4. with ground control switch on the engine runs extremely high RPM, is this normal? In platform it idles down and when foot switch is depressed the idles raises, but in ground the engine screams, I'm guessing 3K+, I'll try to tach it somehow.
5. forward drive is messed up, pushing stick forward unit moves then at half way unit starts bucking and acting up, reverse is fine throughout range.
6. sometimes the unit swing does not work, is that tied the the off level circuit? If not it's prob electrical
I'm slowly learning the diagrams and trying to understand the circuitry but it's huge.
The wiring is 95% unmolested and looks good up to the basket where there's a few splices and sheaving missing.
Sorry about rambling on and Thanks for the help
