dwhite22285
A friend and I are buying a 1995 JLG 40HA with the Deutz Diesel engine, I need it to put up a steel building on my property, and he needs it to do some work on the outside of his house. We are paying $1,000 for it so it is worth more than that just to haul off as scrap. I am hoping to trade it off to a guy for a skid-steer once we are done with it.
What I know:
It had been sitting for 5-7 years, I put a new battery in it and it fired up without issue, I think it is locked on hi-idle though as it seems to be idling pretty high, I am guessing low idle was bypassed because it caused issues or something, or maybe the idle selector stopped working. I am not real concerned with this and should be able to fix it or leave it as-is.
It would not go in forward when we started working on it, I found a broken wire at the drive pump and now forward works.
4x4 SUCKS, it only spins one tire if it is in any sort of mud (it was in ALOT of mud, took us 3 hours to get it out)
Our MAIN problem is the tower/upright cylinders don't function properly.
Upright cylinder has not moved at all since we have started working with it, the tower cylinder went up but will not come down. We are wanting to get this thing on a trailer to get it home so it is not sitting in the guy's parking lot, but with the tower up it makes it pretty tall and we are worried about power lines, plus, it won't go into hi gear.
How can I get the tower to come down, and is there a reason the upright cylinder might not be extending?
Thanks for the help!
What I know:
