Keith Lavery
2001 jlg 40h. My lift was working fine, and then it died in the air and so I had someone start if from the ground and when they would switch it to platform it would die. I finally had them just bring me down and when I switched it it worked fine. Later it quit working again with no luck figuring out what happened. I can control from the ground but can't move the machine because the drive contols are in the basket. Any help would be appreciated since it is parked in front of our local fire station
The basket was rotated to the left all the way when it quit working the first time if that helps.
Also I noticed that as soon as the switch is flipped, I lose all voltage at the meter.
