1693TA
Can you post a couple views of the coil itself?
Oh! That's not Racine.
Those are called FPS valves.
OOPS, I miss led you. Sorry bout that. I'll try and find the old coil and get pics. I think it is at a friends. Didn't throw it away.Oh! That's not Racine.
That is a very accurate statement. Are there any identifying marks on that solenoid coil at all?The valve for the high drive was a Racine valve. I just assumed all the valves were Racine. Assuming will always get you in trouble. Thanks, Jim
No, not a one.That is a very accurate statement. Are there any identifying marks on that solenoid coil at all?
I'll do that. ThanksI miss led myself you mean! I didn't see a lot of JLG "F" series machines with FPS valves, so my mind is stamped with "all solenoid valves are Racine" and I proceeded accordingly.
The few FPS valve machines I saw were very dependable.......back in the 80's........
do a Google search for "FPS solenoid valves" and you should get some hits. I have no info or part numbers for them in my stash unfortunately
Thanks for everyone's input. I have a lot of research to do now. My next project is to get my 392 hemi in my old Plymouth to sing again
Well I was hoping with using OFF's money and my good looks, we'd have you up and running but then I got to thinking grandpa always said: "Boy, "If" I had a dog that looked like you, I'd shave it's ass and make it walk backwards" so I guess we better depend upon OFF's money only.
Couple things to note here:
Notice the open hole in the metal case is larger than the plastic insert or "bobbin" shown here:
Notice the internal "bobbin" is recessed internal to the metal case shown here:
Read this first fully before acting:
Fashion some type of tool to push on the plastic "bobbin" from above while the solenoid coil sets upright on a hard surface. Remove that straight slot screw which holds the insulator firmly in place. Citing the solenoid coil is "open" or does not "ring" with an ohmeter, place the coil assembly into a pan of water. It is alright to submerge it totally and bring the heat up to just below boiling. Allow to dwell in the hot water for a few minutes. Remove the coil, set it upright on a firm surface and apply downward pressure with your fashioned tool. The hot water should loosen the adhesive bond of the glue they put these things together with.
Once the "bobbin" is free from it's bonding in it's metal shell, try to guide the insulator and contact out of it's encumbrance without destroying it. No matter if it's salvageable or not but do try to save it for ease of assembly. Once apart you will see fine wire that is usually a red varnished color and probably a yellowing clear tape. The tape is called Kapton, and the wire is magnet wire. Both are available via online suppliers as is electrical varnish.
Get a known good ohmic reading from another coil if cannot be ascertained in print. This wire has a finite resistance value per foot of length and figure out how to wind that "bobbin" with new wire to very close to the ohmic value desired. You are probably going to require several hundred feet but it's easy to do. I did all six of mine at the kitchen table. I will look in some books I have but I'm not near as familiar with these things as "OFF" would be.
It says it is open, however I thought at first it ohmed out. Might try and see if is broke at the terminal. wishing for miracles I'm afraidwell, looks like good ol' Google let us down on this one. My search came up empty. You may have no choice but to repair your old coil as 1693TA suggested.
Does it measure as "open" or just a lower resistance than the other coils?
