whatsittoyou
I am having an issue with a JD 310SG the driveshaft broke and ripped wires that go to the transmission. We have the wiress fixed as the schematics show.
We are still unable to move the unit but when we lift it the wheels spin in 4 wheel and 2 wheel drive and the parking brake drum has been backed off as we initially thought that was the issue.
Checked the timer relay and we are getting 11amps in but the relay itself was checked with an ohm meter and it's showing open. I'm unsure if that should be open or closed.
Any suggestions on what else to check or what the issue could be? Unit worked fine until this point.
Unit is a powershift (4 speed in the FNR)
