mg2361
oh ya, the radial pumps usually need a charge pump to supply oil to the inlet. I don't remember how much pressure but I can look in one of my manuals if you need to know- probably about 30 psi
On 310/410 Backhoes that used the radial piston pump the charge pressure spec is 30-50 psi minimum depending on model (all levers in neutral). I remember we would lift the loader arms at idle while watching charge pressure and so long as it remained positive you were good. I think a charge pump would be necessary. I don't think gravity would be enough.
