JD 700J 12V converter problems
farmerlund
North Dakota
Farmer/ excavator
Hey guys,
I have a 700J ser# JXE0194212. The converter that makes 12v for the cab quite again I think. My question is the AC quite also. So does the AC need 12V some how to turn on? Fan blows and condenser fans on rear of cab work but it blows warm air. The AC has always worked very good. I am pretty sure the converter failed again, my radio doesn't have any power and when I test the wiring it has 24v going in and nothing coming out. I replaced it 2 years ago I am suprised it quit again. Dang thing is $500 from Deere. Anyone have a source for a aftermarket one? PN is AT404819. I would like one that plugs right in with out having to mess with the wiring.
Thanks
Theweldor
Western, NY
The Village Idiot
I have had pretty good luck with inverters from the people that install business band radios. Have put several in 24 volt cranes to get power to run 12 volt systems and have been in thier for several years without a problem. Probably will not be plug and play the first time out as you will have to wire it up to your system, but they have been very durable and a lot less $$$.
TNB
Over there
P-on
Hey guys,
Thanks
Yes the heater valve is 12 volt as well..without 12 volts it’s open I believe..
farmerlund
North Dakota
Farmer/ excavator
So it appears that I am not getting something to the converter. my plug has 6 wires. Only thing I have is 24v that turns on and off with key. Nothing else. Tried new converter and still the same problem.
TNB
Over there
P-on
Are you measuring 24 volts back probing the power and ground at converter connector with everything plugged in and powered up?
farmerlund
North Dakota
Farmer/ excavator
Yep. if I slide the probe in from the wire side of the plug while its plugged in all I get is the one keyed 24v.
TNB
Over there
P-on
If I remember the other red is unswitched. Jumper your 24 to the other red via back probe and see how that works. I believe that gets its power from the unswitched side of the fuse block.
mg2361
Pennsylvania
Equipment Mechanic
Converter terminal 1 should be unswitched 24 V (from F4 5A radio fuse) and terminal 2 should be switched 24 V from F12 10A radio/dome fuse). Back probe ground terminal 3 to make sure you have less that 0.100 V for a good ground.
farmerlund
North Dakota
Farmer/ excavator
Also the you are correct TNB, the heater is in the full hot position without the 12v. Nice and cool again. :)
  • Like
Reactions: TNB
