When my loader sits for a week the fuel will drain back into the tank, I use the lever on the fuel pump to fill the filter and open the injector lines and will get the machine to run again and it will be fine as I keep using it. Does the injection pump need rebuild or should something keep the fuel at the injection pump, Thank you.
