flyboyziel56
OK guy's I got a real good brain teaser for someone!!. Got a JD 624G with an electrical problem. we replaced the ignition switch with a new one and yes we wired it up the same way when it went back in. When you crank it up it won't disengage the started. both battery's are new and charged up. Thought it might be the wiring to the started, so I used a remote start switch @ the started and with the key switch off, hit the remote and still the same problem it will not disengage!!. Removed the started and took it to our local shop and saw them bench the unit on there equipment and they said there is nothing wrong with the starter???. the only thing left is to swap it out for another starter and see if the problem goes away!!. Any ideas????:beatsme And yes there is a start relay we replaced that's in line to the starter!!
