xmongo96
I have a JD 410D 285080T serial. Was not moving in any gear tested pressure at reverser got 0psi, adjusted clutch linkage to fully release the valve on reverser now has only 50psi have not checked charge pressure yet but all other hydraulics are working good just sluggish between forward and reverse and 50psi. My main question is where do i add shims to reverser and or new spring to raise pressure and what do i need to do to make sure that i do need to add shims. Already know where and how to adjust the sluggish shift. Any info on this will be greatly appreciated! Thanks
