JD 325 wont start and everything goes dead when key is turned to the on position.
daniel.mckean
Kansas City, KS, United States
I was using my JD 325 out in the field with no issues. When I climbed back in to start it up, it would not start. The battery has plenty of amp to start and is not the problem. When I turn on the key to accessory mode, all the lights come on as they should. I thought it might be seat belt switch, but when I put on the seat belt the indicator light acknowledges that the seat belt is on. I do get a buzzer sound when I turn the key as I should, but once I turn the key far enough, everything goes dead. I checked the ignition fuse and it appears to be ok and even replaced it with a new fuse and got the same issue. Any ideas as to where I look next? Thanks
