Armymutt
Went out tonight to start my new-to-me backhoe. It was completely dead. I checked the battery voltage - 3V. Charged it for the past 5 hours and hooked up a test lamp. Sure enough, the light is on - not super bright, but a glow. I pulled every fuse and relay under the cover on the dash. I also pulled the ignition switch because the key hole is worn and it's hard to tell if it is in off or on. Still have a glow. Multimeter is showing 0.00 amps between the negative post and the cable, and battery voltage across the same location. Don't know if that is significant. I'm a veterinarian and it's been a long time since my auto shop days. Not sure where to go from here. I think the business that owned it never realized it had the leak because they ran it almost daily. The last time I was on it was a week ago. Do these just naturally draw voltage like a modern car and just need to put it on a battery tender?
