I have a John Deere 310C Backhoe that recently started lacking power. I was running it one day and it started to lose power, then would not rev up, gain RPMs. It seems to be running around 1200-1500 RPM but no more with the throttle open. I have replaced the fuel filter, oil is good, diesel is 1 month old. It will drive slow in forward and reverse, the hydraulics work well, but it just lacks power as I believe the RPMs are low. Throttle linkage is good. The throttle open to the screws still doesn't get the RPMs above 1500.
I suspect a fuel delivery problem or injection pump problem. injection pump RE-21773. I will apologize I am an amateur mechanic, but would appreciate help and direction in solving this matter.
