Scout_1969
Problem:
Lost forward direction but now is stuck in reverse.
While operating loader, forward was lost. At first there seemed to be a neutral spot and reverse now just reverse.
Noticed fwd/rev lever movement felt unusual, like maybe more travel.
Observations:
Checked linkage to reverser and it moved with the lever.
Manually moved the arm on reverser to extremes in both directions and still just reverse.
Pulled on rod into reverser, in and out and noticed some movement. There was a shiny part showing, maybe 1/2" or so.
Questions
Is it possible that a pin or snap ring has come off inside?
Can the cover be unbolted to allow access or does the entire reverser have to be removed?
Are there any tests or checks I can do?
Any thoughts would be appreciated.
Observations:
Questions
