JD 310B Backhoe Hydraulic Hose Installation Technique
Scout_1969
VA
What are some techniques to loosen and tighten- the 6 hoses that go from the controls to block on backhoe?
There's 2 or 3 that are really difficult with other hoses on and just a little easier with the other hoses off on both ends.
Tubing/crows feet I have won't work. Even tried cutting the box and open ends of cheap wrenches and used stubby wrenches, I'm still not confident they will hold. They loosened already and leaked due to me twisting the hose.
Spud_Monkey
Your six
Decommissioned
And you might have to sacrifice a few open end wrenches to grind them down to fit the hose and the other fitting going into the valve block.
Scout_1969
VA
Thanks for the reply.
Luckily both ends have swivels they all line up unfortunately making it tight. If they were extended, staggered or spaced further apart, even 1/4” would help. I’ll see how it goes. Here’s pictures of what I’m working with.
Scout_1969
VA
I may have to modify them even more, maybe thinner. The box end cuts are weak. There’s not a narrow spot near fitting to slide up and over like tubing wrenches. Unfortunately I don’t have pictures of my two, but would like to see what others have done.
Swetz
NJ/PA
Electric & Gas Company
I have had luck with this style wrench. Not selling the brand, but they had a pic on google.
Tinkerer
That arrangement looks normal to me.
I don't see any reason a crowsfoot wrench on 1/2 drive extension and a breaker bar or ratchet would be a problem.
Ya have to use an extension to get the head of the ratchet away from the fitting.
It is quite normal to remove 2 or 3 hoses to get at the one that is being replaced.
At least one end of the hose will have a swivel on it. Or it is screwed into a swivel that is separate from the hose.
What he said about the order of March. Sometimes you have to dig away to get to the "one"
This set of hoses on the 120 was fun.
Vetech63
Oklahoma
A good quality 12 point crows foot is your friend........not those HF ones either. I’ve even used air chisel with a flat bit on the flats too loosen and tighten that kind of stuff.
