Scout_1969
somehow I can't figure how to delete an inadvertent duplicate post
You might be hard pressed for space to use those wrenches on your swing cylinders.... the crowd and swing are the same set up are they not....?.... big gland nut?( rod guide nut)
I just took a drift pin and gave it a wrap.... round and round.... Mine were not hard fast in the bore. Came loose easily. Rod came out simple too.
Now... I had a shop replace the seals.... but I pulled the rod on one ( swing) and pulled the whole cylinder on the other ( not needed... easier to just pull the rod with the bore on the machine)
