Jcb telehandler ignition on, key off.
Discussion in 'Forklifts/Telehandlers' started by skata, Apr 24, 2020.
  1. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
    Hey jcb Jeff! I need your help .
    I have a jcb 509-42. It's been parked for a while. But today I heard a buzzing noise and come to find the ignition on. Buzzing. Flashing STOP NOW. S078 and z111 error. The first is a canbus error. And the second is fault list full. Machine has a cab and was locked. So nobody messed with the ignition. And it's dry inside. It rained a lot last night. Water get in some wire harness perhaps? But how could that turn the ignition on? I started the machine and everything worked fine. But I couldn't shut it off. Had to pull fuses. And disconnected battery for now. Any ideas?
    Jcb5cfkgl01403137
  2. heymccall
    heymccall Senior Member
    Feb 20, 2007
    1,922
    Monroeville, Pa
    Try disconnecting the alternator.
    I've had alternators fail that would be similar.
  3. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
    Hmm. Might have to check that.
  4. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
    No error messages today when I looked at machine. But ignition still turned on . Flickered on and off a few times when I connected battery.
    Then i looked at machine later in day after more rain. Ignition stayed on constantly, even after unplugging ignition switch. Waiting for all this rain to stop and dry up so I can dig into it further and check wires and alternator.
  5. skata
    skata Senior Member
    May 10, 2007
    693
    midwest
    Ok. Found the problem. Took the panel off the front of the cab. There's a connector there for a immobiliser, with just a jumper plug connected. Took it apart and it was full of water and 2 pins burnt. One of the burnt wires was a fused ignition feed, and the other was a battery feed. After scraping out the burnt plastic, I could get the machine to turn on by touching the 2 pins together. Its a standard Deutsch connector, so I'll replace it when I get it.
  6. jcb jeff
    jcb jeff Senior Member
    Nov 23, 2014
    375
    United Kingdom
    Yes that is the plugs for the jcb immobilizer you dont have one by the looks of it that are slightly different than the normal DT plug ,need to check the location pin in the plastic housing.
