Hello All, has anyone here rebuilt a JCB Powershift transmission? I am in the process, and things were going good until I realized the original JCB composite pistons were required to be replaced with a aluminum piston. No Problem....However when I replaced the piston, I learned the piston liner ring does not fit. Not sure if when the composite part was replaced with aluminum if the piston liner is no longer required. Any help would be appreciated.
Sam
Sam
