Piston
I have a bit of a brain teaser.
I recently bought a 1994 JCB 217S, in non working condition. I bought it not running, but ultimately got it running and was able to lift the backhoe up to engage the locking pin and keep it in the raised position, then brought it home.
When I bought it, the dipperstick function was 'frozen' in a position other than the neutral position. I removed the spool from the backhoe valve block for the dipperstick. It was a bear to get out, and I ended up "gently forcing" it out with a rubber mallet. I did not see any metal pieces fall out, but my assumption was there was a piece of metal stuck in it.
I reinstalled it, however it wouldn't go in very easy. It is too 'tight' to use. If I were to function the dipperstick it would freeze up/get stuck and I wouldn't be able to use it. I was able to gently raise the boom up off the ground so I could transport it down the road to my house.
At this point it is nothing more than a front end loader.
However, here is the brain teaser. My neighbor had this problem in the past, which seemed to stem from a retired elderly mechanic that worked on the machine and 'forgot' to put the hydraulic filter back in place. After it froze up the first time she had another mechanic come fix it. He replaced the entire valve block assembly for the backhoe with a used one from JCB. After installing it, and replacing the hydraulic filter, and changing the fluids, it was supposedly working just fine, as normal. Then at some point it froze up again and here we are.
I have the old valve block as well.
I took it apart and found this chunk of metal in the dipperstick spool.
After removing that piece of metal, the spool still will not go back into the valve block very easy. I removed the other two spools on either side of the bad one, and they came out like butter. I tried for the heck of it, to put one of those spools into the dipperstick section of the valve block, and it also would NOT go it. It is strange, both backhoe valve block assemblies have the exact same problem at the exact same spool?
Does anyone have any tips or info that could help me out? I can't figure out how to fix this.
