Well we have a JCB 214 Series 3 s/n0900368 on a small island in the Bahamas........we were having problems starting the machine due to the battery not holding charge...........this is an ongoing problem over there due to corrosion......it would start off a jump though...........when i was out there last i put a brand new battery on........when we tried to start it it sparked at the starter and then wouldnt start.....it had blown off the lead which goes from the starter to the alternator....which was heavily corroded...........I replace this lead but still not starting......I removed the starter, cleaned and checked to see if it was working........all ok....checked all fuses including inline fuse near starter and as much of the wiring as i can get to, including behind the fuses and key switch......all ok......when you turn the ignition on all the lights work and the buzzer sounds but the final turn off the key to start it nothing happens.........it is as if the forward/reverse selector is engaged....which is not.......i am now a little stuck as to what it might be......i would appreciate any help if possible, maybe one of your JCBs has had the same problem....thank you in advance..........
