Hi All,
I’m in the process of changing out the hydraulic oil on a Kubota KX161-2. The book recommends shell tellus Iso 46 for between 20F and 70F, and Iso 68 for temperatures up to 90F. With my being in northern Ohio, I don’t expect to see long periods at the upper temperature range.
I’ve read several opinions on which oil to use, some comments mentioning a heavier oil should be used on an older machine due to parts having wear, etc. My KX has about 3,700 hours on it.
Any opinions on Iso 46 vs. 68? Or should I consider a multi weight oil?
