Is this for a manual tach?
Driver2022
Ireland
I screwed this piece out of under the oil filter housing.
The probe at the end spins as if it's a tacho of some sort? Could it be the tacho for the revs?
The engine is a 4bd1 turbo
Driver2022
Ireland
Should have added the smaller piece with the probe screws into this piece below which in turn screws into the bottom of the filter housing
kshansen
Central New York, USA
Not knowing a thing about that engine I'm thinking it is not a tach drive. Does that small part that you said turns have a ridge down one side the would pilot onto a slot down inside the part it screws into?
Sorry if not really helpful but not seeing the parts in person I can only guess. I did try to look at some online books for that engine but could not find anything to be sure what it is.
Cliffy
Qld
Think its a oil pressure regulator valve.
Guessing the top is removable and will have a thread and lock nut under it. The spinning of the pin might be adjusting the length of it and changing the preload on the spring.
Driver2022
Ireland
There is a spring inside there alright which that spinning pin seems to go into.
I'm looking for somewhere on this Isuzu 4bd1 tengine where I can put in a manual oil pressure gauge with a capillary tube.
Syleng1
Communist state of Connecticut
Welder- farmer
1) t into the existing oil gauge lite
2) a mechanical tach drive did not exist that engine to my knoledge. Maybe a pulse generator on the alternator.
