old-iron-habit
- Joined
- Nov 22, 2012
- Messages
- 4,233
- Location
- Moose Lake, MN
- Occupation
- Retired Cons't. Supt./Hospitals
Well so far this has not been a good winter for my old working toys. The other day I was finishing up hauling firewood out, using the Iron Mule forwarder since the skidder went lame. When I went to pick a grapple full I heard a loud snap, a real loud snap. A investigation revealed that the shaft that is the head and boom support snapped. It is a 4-1/2" shaft. It has the turning gears below and a brass two piece shim it pivots on. I found a piece of 4140 shaft locally that I can get to replace it with. It has to have the turning gears welded on with the upper mounting bracket in place making preheating tough. At the top of the head it has a plate welded to the top of the pin and to the head holding the pin up and also turning the head. It snapped off a inch below the top weld. Heat stress from the original weld, overwork, who knows. My question is this. The welding standards say 4140 should be heated to 400 degrees and then cooled slowly. I have talked to two welders whom weld hi tensile steel often. One deals with 4140 often. They both tell me that they heat until the moisture is out and then weld, taking care to not over heat it with the weld. I appreciate your thoughts . I'm concerned a softer steel will bend at the swivel point.
