International 2500 engine compartment.
nedly05
Adk. Mtns, NY
My 1994 international 2500 has nothing to protect the motor under the fenders. Is this unusual? It seems it to me, I was trying to think of what I could put in there to act as a " curtain" to keep debris off the road from damaging the motor.
Thanks!
nedly05
Adk. Mtns, NY
Inner fenders, after doing some research it seems like they might not have any. Would it be a bad idea to build a frame to hold a mud flap to keep debris from going on to the motor Or is it fine to leave it be?
Oldiron
Alberta Canada
the IHC 2500s usually had a rubber curtain about half as heavy as a rubber mud flap that had a rod that held the top in place and the bottom was held by springs , you had to take them off to get at the motor and they ussually got lost, I would think the ih dealer could get them or at least a picture, they would be easy to make if you saw them, as I recall one end of the rod was vertical and the other horizontal , the rod was 7/16 or so thick, look on the firewall for a bracket that would hold a rod that size, they were 2 pieces of flat about 3/16 thick , and an inch or so apart.
nedly05
Adk. Mtns, NY
Perfect, thank you very much!
