Injector pump timing
Crackerjack222
South Texas
Ok, so I have a Ford 7000 that I am about to change out the Simms injector pump. The procedure for this tractor is to line up a timing mark on the flywheel with a small inspection port on the bell housing (with the #1 cyl at top dead center) and have the pump on the #1 cylinder when it is bolted on. My problem is: I cannot find the timing mark on the flywheel. I know there is one because I found it 20 years ago when I installed this pump. I have rotated the flywheel tooth-by-tooth with a screw driver until I am blue in the face and cannot find the timing mark.
So I am wondering if there is another way to get the timing right? Like maybe just making sure the new injector pump is lined up just like the old one when I take it off? There is a slot in the tach drive shaft on the pump that is used to set the pump position and a tool to ensure alignment of the pump. I am going to try again next week to find the timing mark on the flywheel but I am not confident I can find it.
Any suggestions?
Narrow it down a little by getting it into TDC on #1 first, then looking for the mark. Take the valve cover off, and when the back cylinder intake exhaust closes and intake opens right away, that's close to TDC so #1 will be TDC on the compression stroke.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Remove the side cover on the pump.. rotate the engine in the normal direction of rotation.. THATS VERY IMPORTANT..
Just bump the engine w the key to find rotation..
Now rotate engine until #1 tappet IN THE PUMP JUST STARTS TO RISE..
THAT MEANS your on #1 compression..
Remove the cover at the front of the engine, directly in front of the pump..
There’s a timing line on the pump drive gear and a boss on the pump w a timing line on it.. u just line up those lines.. about the 12-1:00 position.
U said u were swapping out the pump.??
MAKE SURE the mdl #’s are the exact same.!!
The tag is between the lines and the side cover..
Just because they “look the same”
doesn’t mean a damn thing.. lol
Crackerjack222
South Texas
Thanks, pumpguy, that sounds like a good procedure to use.
The old pump is a Simms with a tag: P5147. The rebuilt pump I bought is a MINIMEC with tag: P5147/4.
I don't know the significance of the /4 on the new pump. Think that will cause a problem?
Crackerjack222
South Texas
To late to give a damn now ain’t it.?
Well that was a snarky reply and was no help at all. Thanks anyway.
But the rebuilt pump is now installed and the tractor is running good.
QED.
