Naheed,nope it is mechanical injectors.
if i can get the injector timing dimension, i can to it with a vernier caliper as in the past ive been doing that with detroit engines and its works pretty good,its the the same principal i suppose!
Learned something new today, yes I have the "Engine Performance Specifications link" on SIS and see there is a lot of information there, mine talks inches not mm so it shows "2.57 IN" for timing dimension. Kind of strange that it does that these days! OK, took a second look and there is a place to select the measuring system!Hey Ken, you can get the info through SIS. Do you have the Engine Performance Specifications link on the homepage? Anway, if you don't the spec is 65.25mm.
